NAA gas tank bolts
petertay
The NAA gas tank is mounted with three bolts. The two rear bolts tighten down. The forward bolt is 2 inches long with a 1-inch spring and it doesn't tighten. WHY would this be? There is no reason (that I can think of) why the front of the tank should be loose. Thanks for the reply. --Peter
I'm going from memory here petertay, but I believe that spring
was longer than that on my NAA's. It held the tank tight enough
that I had to loosen that bolt/nut to get the tank installed.
I put new tanks on two of them and it seems they were both the
same. Tank certainly wasn't loose and just flopping around up there.
I don't know the engineered reason for that design, but it was
used on later tractors too so possibly it was for flex caused from
terrain or heat?
Most likely to provide stress relief to prevent metal fatigue resulting from vibration and differing thermal expansion.
Whatever the reason, it appears to have worked.
Dean
Happened to think, the back two bolts had cushions too.
They weren't bolted metal to metal. Leather or rubber bushings.
