BarnabyHooge
The carb on my recently purchased 860 was covered in crud and seemed to be leaking gas from the main gasket. Took it off, soaked it in simple green and cleaned it, then rebuilt it using a kit from TS. It runs great now, but I'm getting even more gas coming out of that gasket. I took it back off the tractor and split it and the gasket was soaked. What should I be looking for here? Something causing too much gas to flow in or is there a secret to get this gasket to seal properly? I reused the 4 old screws and lock washers if that makes any difference.
Thanks!
Thanks!
