56 Ford 640 12 Volt Conversion
helm_55
New User
Father in law got this for a steal and my goal is to make it as good as it can be. Runs great, gotta dig into the hydraulics a bit as they won't raise all the way at times. Got a service manual and parts catalog. That being said, I know this has been discussed a lot throughout the years and I'm very new to working on antique tractors. I know nothing about 6 volt sustems. Previous owner replaced the generator with one that does not have the tach drive. Wiring harness needs to be replaced as well. I would like to do the upgrade to 12 volts but I want everything to work and work right. All kits I have found do not have the generator with tach drive, so they're useless to me. Is there a kit to convert to 12 Volts and make literally everything work correctly and does not leave any weak links that the extra voltage could possibly affect? I don't HAVE to convert it to 6 volts but chances are I'm going to be replacing a lot of components between now and a few years and since they aren't using it yet I'd rather just cough up the $ now. Thanks for your help!
Welcome to the forum!
Take another look at that 640. The Proofmeter/tach does
not run off the generator. It runs off the hydraulic pump.
Four speed proofmeter for an 8N that ran off the generator
will not read correctly. 12V conversion wouldn't affect it at all.
There's really not much different to know about 6V systems either.
Other than it seems to be difficult to find a good replacement
voltage regulator. If yours is working and charging, save your
money until it doesn't. 90% of my Fords are now 12V for that
reason. None of my other brands are though. Nor the 2N I just sold.
They have cutouts instead of VRegs and work just fine.
If you are going to convert it, you will want to change the light bulbs.
They really are brighter than 6V headlights if you need to use it at night.
LED's are also an option with 12V conversions and are great.
I also change to a true 12V coil so I don't have to use a dropping resistor.
Less connections to corrode, less hassles. NAPA IC14SB or equivalent.
Sounds like you are a bit confused. The alternator as nothing to due with the tach (Proof-Meter) drive. The Proof-Meter is driven by a mechanical cable from the back of the hydraulic pump, which is at the back of the engine on the right side. 12 volt alternator conversion kits are available, including from this site
The cable is missing and after reading that the kits didn't come with the tach drive I assumed that this was the case. Good to know! So this is what I'm planning on getting: A 12-volt conversion kit, 12 volt coil with internal resistor, a pertronix electronic ignition unit, and a high voltage spark coil. Any other recommendations or comments?
(quoted from post at 15:21:59 10/16/17) The cable is missing and after reading that the kits didn't come with the tach drive I assumed that this was the case. Good to know! So this is what I'm planning on getting: A 12-volt conversion kit, 12 volt coil with internal resistor, a pertronix electronic ignition unit, and a high voltage spark coil. Any other recommendations or comments?
I followed the excellent advice on this thread and very pleased with the outcome.
http://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=ford&th=344550
If the generator is working. I would leave it on six volts. I
have a 640 with Sherman backhoe. I use it every two or three
years. It has always started right up on six volts even after
sitting for three years.
That information about the tach drive on the generator applies to the 1965-1974 thousand series, not to any of the pre-1965 Ford tractors.
