Ford 3400 weight and width
Can anyone tell me how much a ford 3400 with 730 loader weighs and width? I'm
thinking of renting a uhaul trailer and I may have to put it rear wheels towards
front cause of loader and trying to figure put tongue weight, I have to see if tires
are loaded, I have to drive about 250 miles with it
Lots of variables. Wheel weights, tire fluid, counter we, etc... the one I brought home recently I estimate at 7000 to8000lbs
around 5600 lbs unloaded...no weights or ballast and assuming the standard bucket at 375 lbs..
width is dependent on rear tire settings... but usually will be less than 73 inches wide.
There isn't an wheel weights or counterweight , tires may be loaded , my buddy just told me he would let me use his 16 x 8.5 enclosed car trailer which is rated for 7500lbs so I'm hoping that will be suitable
Our 3400 with 730 loader often has trouble moving on any small hill with 3 wheel weights each side and nothing in the loader, so be very surprised if your tires aren't loaded. Basic tractor is right around 4k lbs and loader is another 1000 according to the book. If tires are loaded could be close on weight but should be ok with that trailer
That's going to pull ugly because the trailer is too short to be able to put the load where the trailer is properly balanced.
If it's got a loader, then hopefully it's got a ROPS, which would probably make it too tall for the door on the enclosed trailer.
