3 Pt Lift Problem
Retcol
Yesterday I was going to hook up my Ford 860 to my back blade. After I hooked up the 3 pt wouldn't lift. I unhooked and as I drove away the 3 pt would go up and down. I checked the hydraulic fluid and it was full. What is causing my problem?
Maybe an odd one time thing or could be other problems. So unloaded it lifts so check the simple things. Stand on the arms and see if it lift you. If it does try the blade again. May have had a sticking valve and it free up or may have a bigger problem but with out trouble shooting one never knows
