michael432
New User
just had my ford 600 in to the shop and had the distributor replaced, new carb and exhaust manifold gaskets. it runs great but it sputters as soon as a load is put on. any ideas would be helpful thanks
Does choking it hurt or help?? If it helps then it is running to lean. If it hurts it is running to rich. Also when was the last time you serviced the air cleaner and dumped the mud and water out of it and fill it with fresh oil
Sounds like ignition but uncertain from available information.
Never look to carburetion unless and until you are certain that the ignition is spot on.
Dean
