front hydraulic pump connections for 8N ford
ejensen
Where do I look up front hydraulic pump connectors for loader on 8N ford. Have splined connector attached to front pulley, 3/4 inch shaft one end splined other end 1/4 inch key way, pump has 3/4 inch keyed shaft, Need connector for pump, connector for shaft from engine, ( both pump and drive shaft from engine are 3/4 inch with a
keyway.A piece goes between the pump and the driveshaft from engine
Right here on this sight, go to Tractor parts upper left choose ford ns then look under hydraulics. good luck
As said by the other guy this site sells them. Or a good tractor dealer should have them or be able to get them
