Ford TW door latch
I have a Ford TW10 with a broken left door latch. The parts book shows the outside 1/2 of the handle is a twist handle. Mine is a plastic grab handle with a push button in it. I looked on tractor house and some later TW15 etc. have this style. Does this tractor have newer doors put on it or do these replace the early twist type? Even my local parts guy doesn't seem to know.
I would say the early one was replaced with the later one. I've never looked into it in detail but I suspect that would not be too difficult. If you have the later one fitted, order the later one...
Rod
They started using the grab handle with push button after 10/85, the doors have a different part number so it's likely the doors have been changed on your tractor, or modified to use the newer latch.
Look up parts for a TW15 cab in section 15B01 for the later model latch.
I see the newer doors on the super q cab (II series) vrs the earlier qcab. As said.. the striker latch is different as is the door locking piece. I have some of the earlier (older) door handles and assemblies that go on the door.
