Good news on 640
grandpa Love
No rain ,yet, today so I fired it
up and bush hogged for about 30
minutes. Everything worked like it
should. Lift has been holding
bushhog up for last 45 minutes
while we ate lunch. Tractor is
off,lol. Hope it just needed some
running. Only thing was new Napa
" vented " gas cap was whistling
when I stopped. Took cap off blew
4 ft in air. Lucky I was expecting
it. Thanks to everyone who helped
with this project. Great group of
folks in here !
Does it still have the heat shield under the gas tank?? If it does then you may need a different gas cap since form what you have said you either do not have the heat shield or the gas cap is not a vented type
Got the heat shield. Says vented on cap. Lol. I'm guessing it's mis- labeled. Last one I got from Napa was vented also and I had to drill a small hole in it. Im thinking this will end up the same.
