Hydraulic system will not lift the 3 point5 foot bushhog mower high enough . Installed stay chains to keep the mower at proper height for mowing. Is there a port for installing a check gauge to check the hydraulic pressure of the hydraulic pump? What should the hydraulic pressure be? Hydraulic cylinder under the differential cover that operates the 3 point. How is this cylinder checked?
Would appreciate information on how to check the hydraulic system and what others have generally found to be problems with the system on a ford 861 Have several other tractors; ford jubilee, 8N, TE 20 Ferguson, John Deere 850;hydraulic systems on these tractors lift the 3 point implements perfectly.
