Lynn Patrick
Decided today was a good day to try to figure out why no lift at all on the Jube 3 point. Checked the I&T FO-19, attached a hose to the pump primer hole & fired it up. Full flow instantly! Let it run several minutes, replaced plug & still no lift. I&T then had me pull the cover, which is now on my work bench. It then tells me how to repair each individual part, but not how to tell which part might be failing.
What's my next step?
Oh, & I love this FO-19 manual. Index sends you to #127 which starts out "first remove...as in para. #123". Go to #123, says "as in ...#121". Maybe I should have just started reading from the front!!!
At least I'm still having fun!
