Ford 5600 - 3-point hydraulic backhoe connection
I just bought a '79 Ford 5600 that has four rear hydraulic connections (2 control valves). I just found a 3-point backhoe attachment local to me that works from a single pair of hydraulic connections.
My question is - how do you open the flow/bypass the valve on the tractor to allow fluid to flow to the control valves - unimpeded - on the backhoe?
I'm guessing/hoping I'm missing something simple and this will just work, but I wanted to check with the group before committing to a purchase that will require modifications to the tractor to make it
function.
Thanks,
Tim
Sounds like a legitimate cheat that I might
have to use, but was trying to find out if
there is a bypass detent or position
designed into either of the two levers. I
checked both the operator and service
manuals last night without any luck.
Some valves are detented but it's a pressure release detent and the first time you put a lot of pressure on the hoe the valve will pop back to center shutting off the oil supply.
They make a priority plate that goes under the remote valve for suppling a loader, but unless you plan on using that hoe a lot it's not worth the extra plumbing.
There's several guys I know that are operating loader valves off of a remote with the handle tied back to keep the loader valve supplied, they just have to release the handle in order to use the other valve.
