throttle friction disc for 871 ford diesel
ejensen
Would like to know where to get a throttle friction disc for the throttle assembly: under battery box,nice section out of battery box exposing the throttle friction disc assembly
castle nut with cotter key, Belleville spring, small plate, worn out fiber washer under plate
I made one from a piece of cork gasket material, about $7 for a whole roll of it at Autozone. One roll should last a lifetime.
I have used the same cork disc that goes on the hydraulic quadrant so far its worked out good. I suspect leather would work as well.
Hobo,NC
Great idea!! The diesel in my friend's tractor has a great sound. Sounds powerful. Looks like the gas engine in my jubilee bus similarity ends with look.
