ford jubilee
roy prins
I am working on a ford jubilee -- the hydraulics -- the 3 point goes up to the selected place but then settles a bit and goes back up -- its got the hickups -- I replaced the cylinder and rings and the pressure valve with a new ball -- still does the same thing -- now what ?? parts are limited -- thanks in advance for all and any advice !!
Since you say that you replaces cylinder & rings, other possibilities are gasket under cylinder, ram cylinder safety valve, check valve, and the control valve itself.
