8N belt pulley on 3000 Ford
Richard G.
Loaned a friend 8N belt pulley and PTO adapter to put on his 3000 to pull a nice hammermill he picked up.
Anyone have photos of adapter they made to put between the tractor and pulley unit?
Thanks
Richard
Here's the one I used for my buzz saw and burr mill. Don't think it was homemade. My friend may have a homemade one. I'll see if I can get a photo Sunday when I see him. His looked more like a square block with a big hole in the center. I believe he needed long screws with his. Mine is indented in the middle so short screws on each side.
Kirk
<a href="https://imgur.com/hffI7gA">
hffI7gAh.jpg" title="source: imgur.com"
</a>
Here's mine on a Ford 840. The spacer accommodates the 1 1/8 to 1 3/8 PTO adapter.
<img src = https://s19.postimg.org/o8xllja9f/Belt_Pulley_Resized.jpg>
Can't say for sure it was homemade but here it is.
<a href="https://imgur.com/r0xpaTR">
r0xpaTRh.jpg" title="source: imgur.com"
</a>
<a href="https://imgur.com/BGmih9H">
BGmih9Hh.jpg" title="source: imgur.com"
</a>
Thanks Kirk. I think I will suggest to him to make 2 flat plates. One for the pulley and one for the tractor. Then weld a piece of pipe between them. He is a good welder and has access to plenty of scrap.
I may help him make it.
Richard
A flat piece of steel may work on one side but on the other side where it connects to the tractor it will hit the bolts so you might have to be a little more creative. You can see it in Andy's photo. Something else to consider is if it will be used on more than one tractor because the earlier ford models had a lip that your pipe would have to go over.
<a href="https://imgur.com/956Wy0l">
956Wy0lh.jpg" title="source: imgur.com"
</a>
<a href="https://imgur.com/zRyeFjN">
zRyeFjNh.jpg" title="source: imgur.com"
</a>
