I was given a 1958 Ford 951 that had been sitting for a couple of years. New engine oil, trans oil and antifreeze was good. Gas was really foul so drained that cleaned strainer and cleaned carb. Coil was bad (leaking) so replaced that. Added new battery and presto it lit right off. engine had black smoke so was trying to lean out the mixture. After about 2 minutes run time the engine stopped. I noticed fluid coming out by the air hose and figured that the float was stuck and leaking gas. What a surprise when it turned out to be antifreeze. I disconnected the hose and about 8 ounces of antifreeze came out. Tractor started right up and I shut it down and looked again and there was antifreeze coming out the air intake of the carb. It appears to me that the head is cracked ($$$$$). I have not gone any further to test it out. Anyone had any similar experience?
Thanks
Des
Thanks
Des
