I am having trouble getting the injector pump timed on a 1980 7700 Ford with a Simms pump. This tractor hasn't run for years, and the last time it did it went to full throttle and wouldn't shut off, had to shut off fuel to kill it, that's the reason the pump was rebuilt. According to the shop that rebuilt the pump it's set at the home position and from what I have read from I&T shop manual and online the #1 piston should be 23 degrees before top dead center and the the pump should bolt up, well none of the bolt holes on the input shaft of the pump and the holes in the drive gear line up. I am not a diesel mechanic, but understand timing, I have had many distributor out of gas burners and got it running again. I also understand timing marks, I worked on copiers from 1973 to 2005 and the old ones were timing nightmares. but I always got them running. Any help would be appreciated!!!
