Hey, what does the 730 loader front mount/pump bracket look like? I purchased a 730 industrial loader for my ford 3000 and it came with a mount from a 850 ford so trying to see correct way to mount the front , thanks
Hello Jerry. The pump bracket is a separate part and not part of the main loader frame. Also there is two different 730 loader frames a narrow one for the four cylinder tractors and the wider version for the three cylinder tractors as you pointed out in another post to someone else. Thanks Tony
Hello 66Ford 3000. The 730 is not an Industrial loader not even close it is a standard ag loader. That's why with the correct parts it will fit your tractor. Verses the 740 Industrial loader that will not fit that you asked about in separate post. Thanks Tony
Hopefully I have the correct one , they had it mounted to a 850 ford, does anyone have a picture of the mount plate to what it's suppose to look like? I have the bracket of the 850 ford that they gave with the loader but doesn't fit , I would have to modify it but I only see 2 bolt holes in the axle support is there suppose to be more mount points in the front than just the 2 bolts? Thanks
I would be measuring the inside dimensions of the loader frame to make sure it will slide all the way back and not hit the nose sheet metal before you worry about parts or mounting it. If you posted pictures I could tell you which one you have just by looking at thr front of it. Thanks Tony
Here's the pictures, I think they loaded if not I'll try again
That is a three cylinder loader frame so that will be wide enough to fit your tractor. The best place to see pictures will be New Hollands website or Messicks a large New Holland dealer in Penn. the parts book pages will show all parts for each mounting kits on all tractors that the 730 was designed to fit. Thanks Tony
