TractorLinks.com
Show Parts for Model:
remote valve operation
TimPa
09-13-2017 13:02:39
my '78 3600 has a dual remote under the seat. the one pair of hoses goes to the dunham-lehr 22 loader, which has it's own pair of operating valves.
can someone please tell me what the valve positions of the 2 handles are supposed to do? does one handle operate one pair of remotes, and the other valve operates the other pair? or is it one valve for supply and one valve for return??
(to date, i have always placed both valves forward for loader use, and center for 3ph arm use)
Destroked 450
09-13-2017 17:56:40
 Re: remote valve operation in reply to TimPa, 09-13-2017 13:02:39
The loader already has a valve on it, why would one want to change it and tie up both of the remotes.
Dean
09-13-2017 20:20:04
 Re: remote valve operation in reply to Destroked 450, 09-13-2017 17:56:40
The other valve is already tied up when using the FEL.
See below.
Dean
Dean
09-13-2017 17:46:00
Your dual spool TISCO valve can control two circuits.
Why not just use one spool for the FEL lift and the other for the FEL bucket?
Dean
Larry NCKS
09-13-2017 14:47:22
You asked this question . . . or one dang near like it . . . two weeks ago.
Did you not read the replies then?
Bern
09-13-2017 13:25:44
You are correct - one handle for each pair of remote couplers.
Each handle has 3 positions: the center is neutral, where no oil should flow. Pull back for raise, and push forward two notches (through neutral) for lower. Of course, "raise" and "lower" assume you have the hoses properly plumbed in the couplers. In other words, the action will be backwards if the hoses are attached backwards.
Be advised that if you're flowing oil through your loader valve with one remote, the other one will not function. In an open center system, oil will take the path of least resistance, which is your loader valve if it's flowing.
