lastcowboy32
My 3000 is starting to get harder to use for mowing and baling because the throttle won't stay put.
I now find myself needing to hold a hand on the throttle to keep it high enough to maintain 540 RPMs at the PTO. If I let go, it just settles back to about half throttle.
Is there a jam nut under the display panel? Some spring on the carb linkage that I should adjust?
As it is, I can't comfortably get into the old "farmer G-lean" where I put my right hand on the fender and sit a little sideways to easily watch the haybine or the baler.
