After all the hassle I had fixing the hydraulics in my Ford 4000 I finally got round to attaching an implement to it - a Wessex Scrubmaster topper (big chains instead of blades). It weighs a good half a tonne and the arms lift it without an issue (was a doddle unloading from the trailer with the loader too!). However, the lift seems a bit jerky and I thought I'd have a look underneath it once I'd switched the engine off but it started lowering immediately. Not as fast as it would with the lever in the lower position but I had to be quick to peek underneath before it hit the floor.
Those of you who were aware of my hydraulic issues also knew that the PTO didn't stop spinning. With the mower attached and the PTO disengaged it does spin lazily, not really fast enough to cause any damage, I'd say. With the mower on the floor it stops. Engaging the PTO turns on the fury and I've been hard at it this morning! Glad I bought something with chains as hit a brick within 5 minutes...
