Sharkbait24521
I've been having a bit of an issue with my '68 manual shifter sticking in reverse of late. This guy gets very little use but is handy when I need it to scrape the road etc. and want to keep it working. I pulled the shifter plate and found chocolate milk in the housing instead of oil. Yeah, I know, water in the oil. Don't have the manual so was wondering if anyone knows what spec that oil should be and quantity. I'm figuring there's several quarts of water in there and making the shift difficult. (Praying it's not some sort of synchronizer worn out.) Also, a friend said there should be a plug on the side that you remove and fill till it runs out there. There is no dipstick for checking level. I've heard that I don't want to overfill it.
