85burbanator
Got the new parts in and had a small window to get some stuff done. Knocked the old seal out (garter spring on the gear box side of the housing if that makes sense) and put the new one in the same way I removed the old one. The new seal (#83924924) has some rubber on the outer rim which tore alittle bit. I tried the manual and Internet before posting to make sure I put the seal in correctly and that the little rubber bits shouldn't hurt.
New seal installed, that's the short side of the housing obviously
Old seal,
Old seal,
