Ford 705 Snow Plow Fitment
Rod330
I purchased a 1972 Ford 2000 tractor and the prior owner included a Ford 705 snow plow frame. Unfortunately, someone had previously cut off the blade but I imagine a replacement could be fabricated. Instead of using this with my 2000, I'd strongly prefer to use it with my 1960 Ford 841. Does anyone know if this would be possible without modifying the frame itself? Photos attached. Thanks!
I can't say for sure, but I don't believe it would be a direct bolt-up.
I had to build that frame for my 3000, sure wish I had one for a pattern!
With a torch and a welder, it will work.
I suggest you either use it on the 2000 or
find the right one for your 841.
By the time you build a mount and find a
blade you're into it for way more than it
is worth.
By the way, All of those Dearborn and Ford
blades will fit on your frame. From the
ones that were made to fit an 8N through
the 3000s the frames changed and the
method of lift changed but the blade with
the turntable to angle the blade are
identical. I have that same frame and
setup for my 3000 but found a 7' blade for
it.
Only 7' I have ever seen.
