cgun
Jubilee checks at add mark before and after adding oil. No leaks and does not smoke. Where could oil be going? Transmission?
Cgun
You add oil and level on the dipstick doesn't change? It has to be going somewhere.
Where are you adding the oil?
The Jubilee has 4 places for oil. The engine the transmission the hyds and the rear end. If you pour oil in the wrong place it will not get it the 2 dip sticks that is has
putting oil in the oil breather hole, right front of tractor. Checked oil at add mark, added about a half quart and rechecked oil and could not tell any difference.
cgun
That's the right spot to add engine oil. If it was right at the add mark, it was a quart low. Still should have been able to see
the difference with 1/2 quart added. If it's still at the add line, add a quart and see where it is. Maybe it was more than a quart
low, but just had some splashed onto the dipstick up to the add line.
Worked on a 2000 Ford for a buddy. Oil was always low after running.
Drains in heads were plugged with gunk. Took hours for oil to drain
back to pan.
