petertay
Our NAA front wheels have negative camber. Did Ford try this for a while or do I have damage. It also has a loader, so perhaps things have been stressed. Axel halves are firmly bolted, and when jacked up, nothing seems loose. Could it be that the axel is bent? If so, it's not obvious. Coments appreciated. --Peter
I do not know of any manufacturer that did negative camber, axle bent, spindle bent, or spindle bushings really worn.
Negative caster was used to make them steer easier.
