Will a ford 4500 loader fit a ford 3000?
Will a loader from a ford 4500 fit a ford 3000 ? I've been looking for a loader local
and a guy a town over has a 4500 loader complete and didn't know if it would fit my
ford 3000, if not what loaders fit? thanks
would take lots of engineered bracket work front and rear,plus coming up with a front pump big enough to feed it, and I doubt the front axle and spindles would make it through the day with that much weight
4500 loader bolts to the front axle bolster which is similar to one used on a 5000, 3000 doesn't have anything like that.
Then there's the hydraulics, 4500's main tank,fill port and filter are all built into the radiator shell that bolts to the front axle bolster.
Then there's the weight, that's one heavy loader, my 4500 didn't have the rear hoe, even with loaded tires and a barrel of weight you where limited on what one could do with it, I could see it wadding up a 3000's front axle in short order.
