Texasmark1
65 3000. Installed after market PS.
Set up front end per serv. manual specs. for regular OEM tractor. Even with the rear brake applied, when I make a turn, the outer front (3 rib 550-16) tire digs a groove in the ground/grass. Anybody have this type of a problem and have a cure? Otherwise steering is super, no shaking, vibrations, shimmy or any of that. Front end is tight.
