Naa piston pump shaft seal
cgun
I installed a new shaft seal on my jubilee hydraulic piston pump. This seal is a double lipped with a garter spring on the larger lip. The other side is shielded. I put the open side with the spring toward the wobble plate which is how it showed in the FO-19 shop manual. The manual details state to install it in the other direction, toward thr gear. Which is correct?
Thanks
Cgun
