I have an end loader with the hydraulics tied into the 3 point hydraulics. I am told I can only use the end loader when I have the 3 point arms chained down. My question is, the loader only works if the lift control is positioned to raised lift the 3 point. Is this correct?
The service manual says when checking the pump pressures not to hold the control lever in the lift position for more than 10 seconds with the arms chained down as it might damage the pump. So am I doing something wrong or do I operate the end loader with the control lever in the lift position?
