Ford tractor model information help!
Hey !, so I'm having trouble decoding my tractor after trying to set a cab on from a different tractor that should be direct fit to my 3000, my rear end is much more narrow than another 3000 so trying to figure out what it is and where it was made?if any help would be appreciated , the 3rd picture is from the rear end axle, and 2nd picture is where I can't find another brake assembly so narrow or the same for a 3000 thanks!
I don't see any pictures either. What are the numbers stamped into the flat spot near the starter?
It could be a narrow orchard model, or it could just be that your rear wheels are adjusted all the way in to the narrowest track. The rear wheel track width is adjustable.
(quoted from post at 06:45:56 08/30/17) I don't see any pictures either. What are the numbers stamped into the flat spot near the starter?
Serial number beginning with an A means it was assembled in Antwerp. They didn't always stamp numbers the same way the Michigan
factory did... you may need to check the opposite side of the bellhousing for more numbers. 6B10C would be 1966, Feb. 10, 3rd
shift. B116 - I'm drawing a blank there... hopefully the model number is on the opposite side.
That has to be an orchard/vineyard narrow model. Those axle trumpets are considerably narrower than a regular 3000.
That would be an orchard model I think. You're in for some special fabrication work if you want to make that cab fit...
Rod
(quoted from post at 18:49:48 08/30/17) The model number for a 1966 3000 narrow would start with 331 and a narrow orchard would start with 333.
thanks for the input!, I don't see any other numbers on the side,there is a Ford number on the trumpets if that will help
