I have a 1720 and installed a new double clutch on a resurfaced flywheel. Put everything back together and the PTO will not operate under a load. It engages, but when you drop the bushhog and start mowing, it will come to a complete stop. It does not affect the rpms on the tractor. Also, with the double clutch, the pto should engage as you push the clutch all the way in and transmission should engage when the clutch is pushed in half way - if I'm not mistaken.
As it is right now, as I let off the clutch, the transmission engaged about halfway up and then the pto will engage just after that.
I am told it is a clutch adjustment. I've adjusted the petal several times, but no change with the pto. I've broken the tractor down 3 times mostly by myself, so a few more times is no big deal. I've adjusted the bolts on the three fingers several times. Originally left it as it was shipped. Then adjusted them to match up with the old clutch. Nothing has changed. It's as if the pto disk is slipping on the flywheel under a load. Don't know if that is possible, but that's what it seams like.
Anyone have the magic solution. I'm to the point that I'm tempted to take the new disks and pressure plates and rebuild the old clutch.
