I have just bought this tractor which really runs great. There are many things wrong with it that I am trying to address.
Firstly, there is no wiring harness other than a wire from the alternator to the starter and wires from the starter to the ignition key. I am ordering the whole wiring harness and have a few questions.
Where is the water temp sensor?
There is a sensor in the intake that has 2 spade connectors and what looks like a hard line(tube) that has been cut and squeezed closed. Does it perhaps go to the engine block? as I see another coming out of the engine block that has been cut off.
Also, I managed to wipe off the paint covering my info tab, and am not sure if the hood has been changed or if this is a 5000, because the numbers are,
C350277
Model E1014C
2H18B
Rear axle 2F07B
2G10A cant tell what this is
Looking on the net, This tractor clearly looks like a 6600.
Thanks in advance for any and all help.
C350277
Model E1014C
2H18B
Rear axle 2F07B
