neighborBOB
Hi Folks
I have a 730 series loader (19-425), attached to 1969 Ford 3400 tractor.
It's time to replace the large diameter (1.5") suction hose. I "think" this is part# 196646 suction tube 37.3 mm ID x 76.2mm L, SAE 20R1? (This is the bigger the return hose with the spring in it, coming off of the filter return.)
I'm pretty sure that this is the part#, but not sure (and my local tractor parts places aren't sure as well).
I have a chunk of radiator hose, Gates 21610, which is SAE 20R3-4 quality, which is better than SAE 20R1 quality (based on what I'm reading).
Is this an OK choice, it does not have the "ribbed" flexible style of the original, but appears to be plenty flexible (and I can put it on in a longer length and probably put the original spring back in it)?
Or does anyone know the REAL FORD part#?
Can post pictures if needed.
