Ford 601. Has been running great for months but the other day it died and won't restart.
It turns over, fires, runs rough for a while, then eventually dies. Playing with the throttle and / or choke lets it run a little longer.
Within the past year or so, the tractor has had a new distributor, new head gasket, valve job, converted to 12 v, new zenith carb, and added in line fuel filter.
Had used just a day or two before but this time after running a few minutes - maybe 10 to 15 - it died and I have not been able to get it restarted as noted above.
I thought maybe it might be not enough gas or a vacuum with gas cap. Added more gas and loosened the cap. Same result.
I replaced the in line fuel filter with a new one. Same result.
I put the previous Marvel carb back on. It started and ran slightly longer but still died.
The Zenith carb appears to flood. The Marvel doesn't. I took zenith carb apart and checked / cleaned fuel float valve. No change. I am not sure if the problem is flooding or fuel starvation. There is visible gas in the in line fuel filter and it runs out the back of the zenith carb so it does not seem to be fuel starved but rather flooded . May partly have been me choking over and over though. the Marvel carb is not flooding. I suppose it could be bad too and is blocking fuel.
I would appreciate suggestions on what to do next:
- could it be the coil? I have read that can cause a problem like this but it is usually 15 min or so after it warms up
- should i rebuild or replace the carb?
- could it be blockage from the fuel shut off?
Anyone have any other ideas.
