901 diesel leaking
trmccrary
New User
I have a 901 Power Master diesel. When you remove the valve cover you see the injectors. Theres a line that connects to each injector. That line is leaking which causes diesel to be in my oil. Can I solder it myself? If so what kind of solder would I need? This line is it called a excess fuel line?
As much vibration as goes on there, I think I'd replace it. I guess one might braze it if good with a torch.
I suppose some may call it "excess fuel line". I call it the return line, as do most in my area.
I had the same thing happen on my 861D. It was putting diesel in crankcase. Sure cleaned up the inside of the motor. I had a welding shop braze it. Not one of my better skills. I asked him to put it in a jig so it wouldn't warp during heating process. Did it for a reasonable amount. I do check the oil frequently so it don't happen again. Looks like new.
