Got it out first time this year .new fuel pump just put on started right up. Was backing up to hitch rake and i stalled it didnt want to start left it sit and i took a nap went out about an hour latter started right up. Any ideas would be helpfull.
On a 6000 diesel air may be trapped in the filter or lines after you have had fuel lines open. You may have to bleed it a couple of times after you get it running, or use the "rich start" button and it will usually start back and keep running. This is common with the Simms pump.
