4000 Ford 5 speed tighten up
riveroadrat
Has anyone out there ever pulled the front bearing caps on a 5 speed to tighten up that end while the input shaft is out? Can you replace the top and bottom bearings? I know I can replace the bottom shaft bushing. Also can you take up some slack in the upper and lower shafts through the hydraulic top cover hole?
the end play in the 5-speed is adjusted with shims at the rear of the transmission - there's not much that can be done at the front without complete disassembly -
