Carb Tuning of Ford 600
Dhasso
New User
My motor runs pretty good but pops every now and then. If I pull out the choke (engine warm) I find a sweet spot that eliminates the ?pop?. Any ideas on
adjustment?
Thank you in advance!
Dhasso
Many carb problems are found in the ignition.
Have you checked your spark with an adjustable gap spark tester?
They're about $8 at the local parts stores here.
Should jump a 1/4 gap in open air.
Enriching fuel, by pulling the choke, can help it run with weak
spark but may also wash oil off the cylinder walls.
