5600 speeds?
pt756
if you have a 5600 with dual power and one without if you are in 8th gear high range would the top speed be the same? or is the one with dual power have a faster 8th gear with the dual power ahead? thanks
Put it this way.... dual power 'high' is 'direct' drive... so that ~should~ be the same as the 8 speed. 'Low' is an under-drive range.
Rod
