jeepfreak1982
New User
I am needing to replace the starter button on the transmission. When removing the gear lever, do I have to remove the woodruff key and associated spring? If so, how do I remove the key and put it back together? If anyone has pictures or a video, that would be even better. I have the shop manual but it assumes the mechanic has a level of knowledge that I don't have, hence the question.
I bought the tractor used, obviously, and the wiring was all funky. Recently the battery stopped charging, but was otherwise running fine. When trying to diagnose the problem, I discovered the weird wiring job. So, I have rewired it following the original wiring diagram and replaced the starter relay, ammeter, and voltage regulator. All I have left is to replace the old, abandoned, starter button. I figure from there, I can make modifications and repair the generator if need be. Also, how does the button start the tractor without two wires? I know its a round about way, but I believe I am fixing future problems.
Thanks,
Patrick
Thanks,
Patrick
