Golden Jubilee hydraulics
cgun
Can someone tell me what the larger hex socket screw plug directly below the larger acorn nut on the right side of housing is for? This is almost even with the right foot board. I have some oil seeping from it. Could this have anything to do with the piston pump not holding prime?
Thanks
Charles
(quoted from post at 20:51:38 08/12/17)
Thanks
Charles
ot likely to cause prime loss. That taps the pump output (high pressure test port).
