Bern
- Location
- Mount Vernon, WA
When you polarize a charging system that uses a generator, you polarize the generator, not the regulator. That said, it can be done at the
regulator if you flash the field wire, and not the terminal on the regulator.
Try flashing the generator "F" terminal with a battery that has at least 12 volts. No flash = open field which means it won't charge.
