5600 dual power?
pt756
we have a decent 5600 it does not have dual power, its in good shape with recent overhaul and looks good, can the dual power be put in? would you need to get that whole center section? also what are the speed ranges our 6th gear is slow for raking and 7th is to fast would 7th in low range be a little faster than 6th in high range, also thought about 34 inch tires now we have 18.4 by 30.s on how mush would you gain by going to 34 inch tires just need a little more speed on the hay rake and tedder. thanks
You could piece it out, but that would be expensive. Myself, I'd look for a donor tranny. You would also need the shift handle/linkage/cable, as well as the external hydraulic plumbing.
