Michael4224
New User
Hello Ford Team,
I have a Ford 861 tractor that has been converted to 12 volt. There is a 2 terminal junction box and a 2 terminal headlight push/pull control switch located on the side panel.
I have bought all new 12v gauges, dash accessory light, and headlights.
Some of the guages have 2 wires and I'm not sure and I'm not sure what junction box terminal the guages connect to and I don't know where the dash accessory light should be connected so it only comes on when I pull the switch to turn on the headlights.
Also, do the 12v headlights require 2 wires or is the single wire that was used on the original 6volt system sufficient to use?
I would appreciate any help that's out there!
Thanks,
Mike
Thanks,
Mike
