Ford 2000 tractor steering gearcase question
Folks this is on a 64 Ford 2000 tractor w/gas engine and 4 spd trans. Looking through my reprint owners manual and listed under maintenance is requirement to check lubricant level at "steering gearcase plug"? question is where is that cause I cant find it. I could be looking right at it (or my model doesnt have one?) but see nothing that meets that description? According to diagram it should be on bottom right side of steering column assembly? any help/advice (or picture of damn thing) would be appreciated.
Here's a picture of the steering box on
my Ford 650, it's much easier to see
since the tractor doesn't have original
sheetmetal,I made my own when I added
the cab, my finger is pointing to the
plug. Hope that gets you a better idea
where to look
For you that have leaks in the steering arm seals and can't get the spline to turn loose so you can replace the seal and packing, I use
Lubriplate 105 in the tube. Viscosity half way between 140 gear oil and GL2.
