CowboyTheOne
I have a 600 Series Ford, Namely a 631, with the Ford Red Tiger Engine. I've replaced all the electrical components on the tractor. New 3 post 12v regulator, new resistor, new 12v coil, new dist, cap, new points, new condenser, new rotor, new plug wires, new plugs. All top brands. I replaced any wires spliced together, with wire crimp style connectors. I still have no power coming to the coil. I also replaced all connectors between the points and coil, and installed new wiring and connectors. Still no fire to coil. Before I did all this, at times you could grab 3 wires that apparently came down from the dash, pull on them, and the tractor would fire up, instantly. Could a loose wire on a gauge cause this problem? The gauges were all new when I bought the tractor several years ago, plus it's always been stored indoors, since I became the owner. Any ideas??? One last thing, when I turn the engine over now, the rotor, strikes the cap and pops it a loose. I can't find the old rotor to compare. I ordered most of the parts through this site. Thanks in advance! :?:
