perryjosh64
Folks sorry for the repeat but thought I'd get better response with new thread.
I have 1964 Ford 2000 gas tractor w/4 speed trans. I've recently noticed a slow leak coming from the PTO shaft. I've had a slow leak from the inspection plate cover for awhile and just keep adding fluid as needed. I'm told I probably have a seal leak inside trans but won't be able to stop/split tractor until probably next year (time/money). Diff and lift fluid are good and remain constant while trans fluid has to be added on occasion.
My question is can I continue to use tractor doing light/medium work (mowing/dragging pastures once a month, light harrowing in grass seed, etc) or am I heading for train wreck ?
