I guess a lot of us have struggled mating an aftermarket 6 loop rim to a Ford wheel center, I know I have. Usually I can find a way to get all 6 bolts at least started, then just force it together. But I've got one that seems even beyond that. I've got all of the bolts in, and 3 of the stations are good, but the other 3 look like no amount of force will mount them. The wheel center is up against the edge of the loop base and the rim would have to distort a whole lot to get them up on top of the base so they can tighten against the loop. 2 of the ones like that are close to 1/8 away from being up on top of the strap. Pics below of one properly fit and one that has a long ways to go. Should I just concede that the rim is beyond forcing together and just grind down all of the loop bases to make room?
Thanks!
Properly seated
A long ways to go
Thanks!
Properly seated
A long ways to go
