fixitforfree
My original Ford 4630 manual says engine oil capacity is 7 quarts with filter change but my dipstick shows the oil to be at the bottom of the hatched area with 7 quarts. This leads me to believe it holds closer to 8 quarts. The twist is my tractor has a factory oil cooler while my manual says nothing about tractors with the oil cooler hold more oil. Also, the factory manual shows a close up photo of the oil filter area on a tractor and it does not have an oil cooler so I assume the oil cooler was an option. It makes sense to me that a tractor with an oil cooler has to hold more oil. I just want to put in the right amount and I don't know what that is. This tractor is new to me so I have no previous experience with it. I called my dealer and he read through some service bulletin's related to both the dipstick and the oil cooler but neither mentioned a tractor with a cooler held more oil or not. Can you guys help me or off suggestions? Thanks.
